tarior What would be a good passenger side drop t-case to use in place of the NP 208 in the '81 J10? Four speed truck.
jeepsr4ever Not much you can do their I believe you have a 32 spline input. Something wrong with that T-case?
mrtazwrench jeepsr4ever wroteNot much you can do their I believe you have a 32 spline input. Something wrong with that T-case? a J10 has a T176, should be the same as a 727 case, the 4spd in the 80 up J20 was the T18 with the different input on the 208. so you should be able to put a dana 300 on that trans if it's still stock. :t:
mrtazwrench tarior wroteSo, if it's a T176, then SOL, if it's a T-18, Dana 300 will work? you got that backwards, #-o if it's stock J10 t176, the dana 300 should work, the J20 with the T18 is the one that differs. :mrgreen:
fifesjeep yup mrtazwrench has it right... If you can find an 80 Scout D300 you can bolt it up to the T-18 8) But finding one of those D300's is like spotting Bigfoot.
