well i think i found my problem..
i tried a new dry filter and still nothing. soooo i pulled the pump again and took a closer look.
this is a pic of the midplate i got from Bulltear.. if you notice the two gaskets are the same. .010.. both have the gear relief both came with my s.s. midplate kit. it got me thinking.. duh.. the gasket between the adapter and the midplate should not have a relief cut for the gears.. so i wonder if i recieved the incorrect gaskets... i looked in the product section and sure enough the photo shows 2 different gaskets, just like i thought..
so what i did was slap on my old oil filter adapter and gasket and BAM i had oil pressure in about 2 seconds.. 60 psi...
tried it again this morning and it still had a prime .. took about a half second to build pressure.
so maybe MC can drop me the correct gasket in the snail mail so i can button this thing up? or am i way off base here?
