FuzzFace2 wroteWhat I didn’t have it covered with my last line “I am no expert……..but I did stay in a Holiday Inn once!”
Quote1: With todays technology it may be possible?
That's why I asked if it was possible to produce something now, not why it wasn't done in the first place.
FuzzFace2 wroteQuote2: When you where talking steel sleeve I was thinking where the gear mesh side to housing is. I was talking about the end of the gears opposite end of the midplate. I guess a cup like sleeve was what you where talking about?
The bottom and sides are where most of the wear takes place. I figured that someone who knows more than me could chime in about lining the top. I didn't want to suggest any particular solution because I don't claim to know what's possible and what's not.
FuzzFace2 wroteQuote3: improving reliability? None and I am sorry I did not add any thing to that topic. It was added for food for thought is all.
That was the whole point of the suggestion.
FuzzFace2 wroteFood again: what is the mileage on the motors being pulled apart where you find the pump/housing bad? Was the oil/filter changed every 2500 to 3000 miles.
It is nice to have a housing/pump that is more wear resistance than stock but do you think our motors will be put thru the every day hell they did back in the day? I think not but it would be nice to be able to repair a housing that is worn out and why I said about the bigger gears.
Dave ----
When I get the freeze plugs fixed in my freshly rebuilt 401 (machine shop screwed them up), I'll be driving my 1977 Cherokee every day, taking it off road and even towing with it. It's going to get every bit of abuse that people threw at these vehicles back in the day. I would like to have the oil pump last as long as possible, giving me the oil pressure that keeps the engine alive.
But it sounds like someone smarter than me has already come up with the solution, a nickle plating on the cover. So that's what I'm going to go with when it's time to get into the timing cover next.
