Picture of my money pit at GAD 05 first time out with car (304) and trany did not shift! It’s a 70 Javelin w/glass fenders bumpers F & R and rear valance, TH400 with custom built converter, AMC #20 rear 4.56 Detroit locker & Moser axles, Cal-Track bars, 10x28x15 MT slicks
Old 304 motor (RIP GAD 06): 10:1 flat tops, ARP rod bolts, stock lower & heads, HS roller rockers, Comp Cams .560 lift hydraulic,260 degrees duration @.050 tappet lift, Torker w/1” 4 hole spacer, Holley 650 dp, Mallory duel point dist. converted to mag. Pickup, Hooker 1 7/8 super comp with extensions
New 360 motor: 74 stock lower end, stock 291 heads, HS roller rockers (old), comp cams 280H 280@.050 lift .490, Torker w/1” 4 hole spacer, Holley 650 dp or 750 dp, MSD dist. 6AL box/coil/wires, Hooker 1 7/8 super comp with extensions. Have yet to put a pass on the 360 but hope to before the end of the year.
Dave ----
