is there a way to extent the stock holley bowl vents or make them like the truck avenger vents to keep the bowls from spilling over and flooding the engine
Yep it's an old trick but it works..Find fuel line that fits the vent tubes put one front and rear then tie them together in the middle to the aircleaner stud..they must be open at the top. (like and upside down y) but remember. What ever you use to tie them off better be secure.. cause if it comes loose down the carb it goes (I use nylon wire ties and leave the tail on them).Also be careful no to cinch them closed or you will lean it out at WOT
thanks that makes life easier at an angle
