I knew that was coming!!!
Go ahead & de-tune it, use little bitty cam, intake, carb, exhaust, etc.
Hell, you could probably figure a way to use 1969 heads for even less power!!!!
You could then paint your front bumper yellow so everybody will know to put their rig in gear & get going again when they see that you have caught up.
Or, a 500+ ft/lb, 500+ HP 401 could be built that delivers over 400 ft/lbs at 2500 & over 500 ft/lbs from 3000 to 4500, redlining at 6500 or less. THAT is for ME!!! (& those are easy numbers from a mild build.
MORE IS MORE!!!
Some trails are WFO & 70MPH+++, some are a-put-a-put-a-put
Over and out (of this thread).
