I would hate for E-85 to get a bad rap. Sure you will have problems if you run it in a engine/fuel system that isn't designed for E-85.
E-85 will knock loose dirt and deposits in the lines, tank and carb that will then flow and plug filters etc. It will also lean a engine out as it takes about 15% more fuel than straight gas.
E-85 rates 100+ octane!! If you can take advantage of that with a boost in compression, run the right carb(not an alky) you could build a pretty heathy motor...down side is you'd be stuck on E-85 with a boost of compression.
Flex fuel cars and truck suffer from the lower BTU of E-85...the big 3 haven't figured out how to increase the compression when the computer senses the motor is running on E-85...hence the drop in power and MPG.
One other thing about E-85 is it's harder to start in cold weather. It's less Volatile than gas.
When unleaded came out, everyone that tried it in a motor that wasn't made for it suffer rapid seat wear. But here we are, it powering everything now. Give E-85 a chance...but do it right, before condeming it.
Taken for the web site http://www.e85fuel.com/e85101/faqs/e85.php
What happens if I accidentally fuel my gasoline-only powered vehicle with E85?
Response:
Although your vehicle was not manufactured to run on E85, no problems should occur if you mistakenly fuel once with the alternative fuel. The largest difference between an E85 powered vehicle and a gasoline powered vehicle is that their computer modules are meant to read different amounts of oxygen within the fuel. E85 contains a higher amount of oxygen than gasoline and E85 compatible vehicles are made to read that higher amount. When a higher amount of oxygen is read by a gasoline powered vehicle, your "check engine light" may appear. A number of other parts on the FFV's fuel delivery system are modified to be ethanol-compatible. The fuel tank, fuel lines, fuel injectors, computer system and anti-siphon device have been modified slightly. Alcohol fuels can be more corrosive than gasoline. Therefore; fuel system parts have been upgraded to be ethanol-compatible.
Ultimately it is a drivers choice, but we do need to be firm in recommending that only FFVs use E85 and to state that we are not responsible for damages.
:mrgreen:
