Rhinolined360
I'm currently on the final stages of my 1979 AMC 360 V8, I need to figure out where the second heater hose line goes, I know that one hooks to the water pump. I need to know where the second goes from the heater core. Pictures would be a help as well. THANKS
AMX69PHATTY
Believe second Heater Hose goes to the heater valve which mounts in the intake manifold on the rear passenger side, should be a 3/8 Pipe tapped hole in the intake. The valve creates a 90 degree elbow. On my AMC car the Heater valve is actuated by a cable that works like a manual choke cable.
fuzz401
cj's did not have the valve there - just a 90 deg fitting
