I spoke with the owner of the butcher shop - UCF MACHINE SHOP IN CARLISLE, PA and he is refusing to pay for another shop to correct and redo the motor correctly. He said that he would redo the motor and fix it at no cost himself.
I do not under any circumstances want these jokers working on my motor anymore. Does anyone know what kind of legal rights I may have? He indeed agrees that they messed it up and that it should be corrected, however he does not agree on the fact that I would like to select the new doctor.
He said "didn't I ever make a mistake?" I replied, yes, everybody makes mistakes and has bad days, but, it was more that one thing you screwed up: 1) cam installed wrong, 2) timing gear installed wrong and no oil getting to the timing chain, distributor gears, fuel pump eccentric, etc., 3) pistons installed .017" down the holes, 4) brand new rod bearings look like they have 100,000 miles on them already, and who knows what else we'll find when we continue tearing the engine apart. Plus, I'm sure if he redid the engine, we'd end up at least .040 over. The new engine shop said they'd take just the bare minimum to clean up the cylinders, then we could order custom pistons to fit.
The other thing is when we took the engine back to these clowns when it first started acting up, they looked at it and said they had no idea what was wrong. Even when we then tore the pistons out and showed them to them, they said they never saw anything like that and didn't know what would cause it.
Advertising isn't cheap, but I think these birds are gonna get some real cheap advertising...only not the kind I think they want!
