AMX69PHATTY wroteNot sure what you mean by "seems to want 20 degrees".
The engine builder told us the best way to time an engine is to hook up a vacuum gauge and adjust the distributor to give the maximum vacuum, then back off 2". That is supposed to be the optimum timing.
When we did that, we got 17", backed it off to 15", then checked with the timing light and are reading 20 degrees BTDC.
Idle is no problem. When we started out at 10 degrees BTDC, the engine was deader than the 258 it replaced. When we advanced it to 15 degrees, however, it ran like a scalded cat. Seems to run even better yet at 20 degrees, but that just seems like an awful lot of timing.
15 degrees base was giving us 35 total at 3000.
