im running a 401 with an Edelbrock intake. Im getting coolant pooling up in the recesses where the first two manifold bolts are. First thought was a leaking hose, second though was bad seal on the thermo houseing. My worst case scenario is the possiblility there is coolant bubbeling up past the manifold bolts......the water jackets are right next to the first two bolts on either side
This is happening while driveing....i can not duplicate any leakage with the hood up, engine hot, and cranking on the throttle cable, as of yet.
My question is, have you ever seen an instance where water seeped up past the forward exhaust manifold bolts? I personally suspect the thermo houseing, but i dunno. Cant find any coolant residue around the houseing. The CJ is at the exhaust shop until Monday, so i cant really do much more investigateing until then, but this question still nags me. :-|
Sidenote: I dont appear to be burning any coolant.....at least from what my exhaust tells me. Knock on wood :roll:
