AMX69PHATTY
Looking for a used AMC TorqFlite 904 Automatic Transmission.
Just the trans alone, or maybe even with the converter and Flexplate.
Pretty sure the 904 was used in just about any AMC car behind 304 V8's after 1971.
Is there a 3rd type of TorqFlite that AMC Used ? a 999 or 996 or sumthin?
I am located in Cincinnati Ohio.
Thanks
fuzz401
I have an auto out of a 74 gremlin that has a 232/258 in it
AMX69PHATTY
Is the Tranny Bellhousing to Block bolt and dowel patterns and sizes the same on AMC strait sixes and V-8's ?
Also wonder if the Tranny internals, hubs planetaries clutches splines, are the same in one from behind a 6 as one from behind a 304.
Know a 904 isn't as stout as a 727 and will have a shorter service life, but can be rebuilt with heavy duty parts. Understanding is that the 904 "consumes" around 30 less horsepower than a 727 due to the fact the internal parts are considerably lighter than those found in the 727. So 30 more horspower of the total produced by the motor gets to the back tires and there is even a reduction in the cars total wieght. For quarter mile runs, any increase in horsepower at the tire and reduction in wieght are both good things.
Would like to find one from behind a 304 since any differences in interanls between it and a 6 are not known, but will keep it on the list as a possibilty while researching information.
fuzz401
the 6's and 8's use the same bolt pattern
AMX69PHATTY
fuzz401, the picture beside the link in your sig does not show up. Is the image file still "good", or is it sumthin' with my system ? Actually a number of images in posts don't display on my system, like the pictures of the block sawed in half in the Engines forum. Thanks for your help.
fuzz401
the picture shows up for me in my sig
AMX69PHATTY
hmmmm ..... so I wonder why more or less NONE of the image files located at the jeepsr4ever/imgbay.com, or whatever, location will display on my system ? Even cut and pasted the webpage image path into my browser, IE 5, and still am not able to view image files.
I'd like to see those pictures of a 360 Block sawed in half.
maybe someone up there is tryin' to tell me I'm not worthy ..... :roll:
Barry Kaul
I have a 727 that's taking up space, if you are interested.
AMX69PHATTY
Hello, and thanks, but I already have a 727 and it has worked great and is bullitproof. Looking for a 904 to maybe try out. The internals are smaller and lighter than the 727. From what I've been told, the 904 consumes 30-35 less horsepower than the 727, which means that horspower gets to the tire rather than being used to spin the 727 Tranny.
Thanks :-|
ozzman104
I have a 904 or 998. whatever came in my 304 javelin. Shifts great. I'm located in Fenton, MI
KEV
AMX69PHATTY wroteHello, and thanks, but I already have a 727 and it has worked great and is bullitproof. Looking for a 904 to maybe try out. The internals are smaller and lighter than the 727. From what I've been told, the 904 consumes 30-35 less horsepower than the 727, which means that horspower gets to the tire rather than being used to spin the 727 Tranny.
Thanks :-|
I don't know if the 2wd tranys had different gear ratios but the CJ/YJ 999's had a 2.74/1 vs 2.48/(in the 727) 1 first gear.Not bad for a 3sp auto, it might get you off the line a little quicker.
AMX69PHATTY
Does the Tranny Pan look like the 904 in this picture ?
What would you want for it ?
How far are you from CinsorNasty Ohio ?
Don't suppose there's any way it could be shipped ?
ozzman104
I'm a lil over 4 hours away from cincinnati I believe. I'd like $150. It is a good tranny complete with torque converter and linkage
AMX69PHATTY
That's a reasonable price. If gas was only so reasonable #-o
Sounds like it's what I'm looking for.
What year Javelin did it come out of ?
May I ask if you could look and see if there are two external ribs on the case above the rear servo ?
If it was from a 304 car it may be a TF-998 Tranny which is supposed to have those 2 ribs,
whereas a 904 does not, which is okay, cause I would prefer the TF-998.
Have been learnin' a lot of info about'em from the internet.
Maybe somehow meet somewhere inbetween here and there ?
Just asking is all, maybe cover some of your gas costs ?
Mapquest says 285 miles from Fenton MI to Cincy.
Like I could drive 2 1/2 hours and that way you'd only have to do 1 1/2 ?
Would that be maybe Bowling Green or Perrysburg OH at I-475/23 and I-75 ?
Mapquest says its 190 miles & 3 hours from Cincy to Perrysburg,
and 98 miles and 1-1/2 hours from Fenton MI to Perrysburg OH.
Hmmm, I guess the danger of looking or asking is a person might actually find one.
#-o
ozzman104
Yeah it's a 998 from a 74 javelin 304. It could have been rebuilt just from the looks of it but I don't know. I'm going to end up using a 727. I've met someone in bowling green before to trade parts. right at the waffle house. It's an added bonus because we don't have them in Michigan. For a little gas money I'd be willing to drive there. You can e-mail me at [email]gelston5585@yahoo.com[/email]
