do you think that all this would be futile for a 5 somethin thousand pound j10?
i was wondering if anyone has had any experience with the crane roller cam for amc v8s
from http://performanceamstyle.com
"Grind # HR-232/352-2S-10. This cam features Intake lift of .563 with 232 duration @.050 with Exhaust lift of .584 with 240 duration @ .050. This unit is ground on 110 lobe centers"
on desktop dyno it appears to have a very broad power range 370 ft/lbs at 2000 rpm increases to 420ft/lbs at 4k with pk hp of 380 at 6000 rpm (with Stock AMC heads and only 8:1 compression) from what i understand a good condition 360 can rev to 6500 for a pinch. If i invested in the forged piston(9:1 compression) also available there, would i be able to do this in an otherwhise stock engine? are the forged rods neccisarry? could the crank take this abuse?
what pushrods, rockers,springs..... would you recomend?
edit: 9:1 compression brings engine to 440 ftlbs at 4k and 420 hp at 5500
