mika01 OK so over the weekend I dropped the 360 into the YJ only to realize that the headers I have need to go. Pass side hits the frame and driver side is in path of the front drive shaft. Can anybody tell me which 360 headers will work with the YJ? That’s other then the stock manifolds of course.
mika01 I'm pretty sure the Edelbrock one will work. Does anybody know if the CJ headman ones will work?
mika01 OK so I think I remember seing a post here abou the Doug Thorley headers. Does anybody think the THY616Y would fit in a YJ Wrangler??? :-|
mika01 I'm thinking since its a pass collector and not long tube headers this set-up might work. Any comments?
pyagid what headers do you have? I was hopeing my Heddman InFrame headers from my cj are going to work on My YJ frame. If you want to do a test fit, We could see if the ones i have work for you before you go and buy something
mika01 that would be awesome, because the Thorley kit is NOT cheap by any means!!!! Also the sooner the better as I want to get this dam project moving. Its starting to test my patience.
pyagid where are you in MA again? I am about 1 hour from Mabell, I could meet you half way someplace if you want
pyagid mika01 wroteJust south of beautiful Woosstaaaa!!! Auburn actually. Are you 1hr south of Mabell? Yeah, down 84 actually in Farmington, and i work in hartford, CT -paul
