I was posting data about compression ratios, preignition, and piston to head clearance in another thread....
LOW compression can CAUSE serious pinging & force the use of race gas!!!
I have a '69 390 that I pulled out of my BBO '69. It was FULLY modified & dynoed 518HP on the HotRod Magazine traveling chassis dyno. It pinged like crazy on anything but race fuel. Upon disassembly & measurement, I found that someone had turned a bunch of material off the piston heads (dished them), giving a .118" piston to head clearance. The math revealed a 9.11 CR.
.045" is what that clearance should be for most steel rod engines (including motocrossers & go karts). The excessive clearance prevented the mixture from getting "excited" (heated) by the rising piston that was trying to squish it.
Check out the GREAT AM turbo books here:
http://www.gatorsuperchargers.net/books/books.htm
I just finished reading the next book, GREAT reading, on Ebay for $12
