Here's something else to consider-
LOW compression can cause serious pinging & force the use of race gas!!!
I have a '69 390 that I pulled out of my BBO '69. It was FULLY modified & dynoed 518HP on the HotRod Magazine traveling chassis dyno. It pinged like crazy on anything but race fuel. Upon disassembly & measurement, I found that someone had turned a bunch of material off the piston heads (dished them), giving a .118" piston to head clearance. The math revealed a 9.11 CR.
.045" is what that clearance should be for most steel rod engines (including motocrossers & go karts). The excessive clearance prevented the mixture from getting "excited" (heated) by the rising piston that was trying to squish it.
In addition, there is much data available from many professional AM builders (Norm Brandes for 1) indicating that a cleaned up AM V8 chamber can go 111 without problems, given proper attention to the tune up. A good fuel system, ignition system, & cooling system obviously would be required as well.
You can also go with over 111 and bleed off some of the compression with a more agressive camshaft. Take a look at all the cams CompCams has for AMC!!!
As far as power numbers, 550HP & well over 500 ft/lbs of torque are easily attainable without pushing the 390/401 past the design's rpm limit, which is between 7500 & 8500, depending on specific demands & preparation.
You did ask for REAL numbers, these are from the V8, your 4 litre design is not the same!!!!
If you happen to get too much compression, a water injection system can be installed quite cheaply to fix, or you could go with thicker head gaskets. Putting extra fuel to it will cool it down & may stop the ping.
Too much cam? That can be tamed somewhat with a lower rocker arm ratio. You could also have the cam advanced or retarded to change where the power is strongest.
The best bet would be for a guy to go with forged 81 pistons & a turbo charger. An adjustable blow-off valve will allow you to set your compression ratio as needed. Actually, the SMALLER AM engines respond the best, with HUGE HP gains available!!!
http://www.gatorsuperchargers.net/books/books.htm
I just finished reading the next book, GREAT reading, on Ebay for $12
