cybergenie93 wroteThanks Mudrat,
I figured out the intake part from the picture, but I wish I had one for the adjustment bracket. I cant believe the bracket has been out three years without a picture or instructions.
?? Adjustment bracket?? Which one are you needing, the lower 'Stand off"? (lower right in the pic)
The 'C' bracket bolt on top, screws in and out and has a stop nut on the back to align the belts by moving the curved bracket in and out.
I'm told the lower stand off that goes between the ALT itself and the block has the same type set up.
I heated and bent a piece of 1/4" plate I formed as a brace for the 3/8 all-thread standoff.
So basically I have a 3-point mount for the ALT to handle torque and tension.
If you can be more specific on your question I might be able to help.
Yeah - instructions would be great .... #-o
