Ya, air bag. I finally found a book @ three different places. Rotate the the cyl. to the run position, push tab on the side of the cyl & the cyl pops out 1/4 way. Then rotate the cyl to the lock position & remove the key to remove the cyl.
I can't do the latter since the key is broken off inside & I can't get the key out! I'm gonna play w/it somemore, if not, I'll use a BH.
Thanks Bob, your alway's a big help. :t:
