anyone know where i can get a new carb insulator for a 360 4-barrel and i need a part number for a rebuild kit for the 4350 carb
I think i'm going to remachine a holley spacer to fit the bore pattern
HfJeff
Ironman_gq, did you have any luck finding a carb isolator or did you modify a holley spacer? Did you have any luck? I am in the same situation. I rebuilt my 4350 before finding out it wasn't the ideal carb. Now I want to use it. You have a part number for the holley isolator you modified?
i just used a holley squarebore spacer and welded some material on to the sides where the secondaries are and bored the secondary holes to match the manifold
you could just bolt on the holley spacer and match the manifold to it and put a holley squarebore on it. I got one off of ebay for 75 bucks
