Hi joey and welcome aboard. And Nope. What I needed was the column shift bushing for the upper shift linkage for the tranny. I can get a pic when I get home (in St Louis now) from the Jeep parts book.
I wound up making one from a 5/16 nylon nut. I drilled the ID to .32 and then turned the OD to .45" and trimmed it down to fit the width of the shift rod; then used channel locks to press it on the rod and into the hole on the shifter arm. Then I turned a flat washer to .34"ID to hold the bushing in place on the rod and made a cotter key to fit the shift rod and hold it all together.
Just getting tired of "making" parts that should be available.
But thanks - :t:
