would the 4barrel intake and carb from a 360 be to much carb for the 304 and would the carb need to be adjusted to make it run right
No it should work great!
thanks I found a yard here that has two of them and I think I can get them pretty cheap
tarior
If those are on 360's, why not get the whole motor (s)?
guy told me if the motor was still there it probably was shot and i didnt have any of my stuff to test them. I went into the yard looking for a brake booster
tarior
If you can turn it with a breaker bar and a 3/4" socket on the crank bolt, it is likely salvageable, a good core anywho. :-|
