ironman_gq wroteI've seen them run a line off of the oil pressure feed to the timing cover and make a nozzle that squirts oil at the dizzy gear
If you take the time to make sure all the passages, from the cam to the dizzy, line up and are clear of obstructions, none of this is nessesary. Check the oil route from the front of the cam, to the dizzy gear very carefully.
