turningwrenches
MY 360 TAKES A WHILE FOR PRESSURE TO BUILD WHEN IT DOES IT GOES TO 60 THEN AT HOT IDLE GOES TO 10-15 HAS WIX FILTER NEW HAND LAPPED OIL PUMP AND SPRING AND ADAPTER IT DOES NOT SMOKE OR USE OIL. HATE TO REBUILD IT . WHAT DOES EVERYONE THINK ABOUT PUTTING IN NEW CAM BEARINGS AND MAYBE SOME NEW RODS AND MAINS. NEEED SOME HELP THANKS :-|
I would measure the pump before I went that far.
turningwrenches
DO YOU MEAN THE COVER CLEARANCE
Yes gear tooth to cover clearance. Might be a issue of the cavity being worn out.
