Swapping in a 401 to replace my 258. The consensus is you have to change the frame mounts. everything i've heard and read says you can use the same driverside frame mount, but you have to change out the passengerside.
I located a set of frame and block mounts, but the frame mounts are exactly like the ones i currently used with the 258 as far as dimensions go...identical. The passengerside even has the same mounting holes. The difference is the driversside mount has different slotting for the motormounts.
I contacted the guy and talked to him about this, and he said the passengerside mount will work fine as long as i use the CJ V8 motor brackets. He runs a 401 in his CJ7.
Anyone have any input on this? pictures of the passengerside mounting assembly?
