Briteblock wroteWhew...I am making those here now and MC would have my head if I screwed even one up. He says the material cost is high on each one because we get it in with a heavy grit finish. I refinish them with scotchbrite on a lathe and use insertable carbide cutters for the hole and press fit OD. The worst part of this process is the dust created by copping them from a long bar
You turn'm from BAR stock not TUBE stock??? :shock:
Hope you recycle the shavings and get some $$ back!!!
