eyotajeeper Did you check NAPA? they sometimes they have things that you wouldn't think they would. If you can't find them there I may have a set if they are the same as for a jeep. Where are you at? Good luck
RWC78 I need the motor mount plates. the Steel brackets not the rubber mounts. I'm located in St. Paul, MN. Thanks.
RWC78 they are the brackets that bolt to the block between the block and the rubber mounts. they are the same for all of the small cars with V8's. thanks
Mudrat RWC78 wroteNeed a pair of motor mounts that bolt to the block for a small AMC. thanks Define "Small AMC" a 4, 6 or 8 ?
Mudrat fuzz401 wrotethe mounts he is looking foe almost look like cj block mounts but a little shorter Gotcha :oops: ! Sorry can't help with those. Pat
