mikew
Just posting if someone may be interested
1988 Honda Civic LX Gold in color
High miles
New Battery, and NAPA Alternator.
Automatic, AC, rear defrost, tilt
Body is in good shape with some rust, its not your average rustbucket.
hit a deer which took out the headlight on the left side and forced the left front fender backwards a bit.
Two owners before me, and clean title except for a rear ender according to car fax.
Some spare parts including including a corner light, but it needs a left headlight from the junkyard, and a righthand power mirror
Motor has 168 pounds of compression
It has a different throttle body/fuel injectors as the original TB/fuel injectors had some issues which I solved.
Issues
Needs valve seals-burns oil
with clean spark plugs it will get 30 MPG on highway, but so so in town.
oil drain plug leaks oil
oil drain plug leaks some oil
Make me an offer, it would be a good car to fix up and drive, I'd like $150
320-583-0471 or 320-587-3722
mikew
If you want to buy it for that, I would switch alternators, doesn't really make sense to run a new alternator in a demo car.
it would be good for mini stock.
