mulescj8
anyone have the part numbers of the fuel pump that will work with the Howell TBI set up........mine went out and i have the numbers somewhere but haven't been able to find them.........need to get this beast fired in the next few days............thanks guys
I believe the GM TBI requires 14-17 PSI. Any pump that will supply that pressure should do the trick. I have a Howell on my CJ, and had a tank built by TrailQuest that uses a factory GM internal pump.
mulescj8
got a part number on that pump?
