afroman006
I've been doing quite a bit of searching here and elsewhere and have come up with a basic component list for the 304 rebuild in my 74 CJ. If yall have any general build advice or parts recomendations they are welcome. The goal is for a mild beach cruiser with a bit of highway driving too. Here's the list of components I've compiled thus far.
Edelbrock cam & lifters- Summit PN edl-2132- $140
Edelbrock intake manifold- Summit PN edl-2131- $186
Clevite 77 main bearings- fastengineparts.com PN ms1041p- $50
Clevite 77 rod bearings- fastengineparts.com PN cb960p- $32
Durabond cam bearings- fastengineparts.com PN n-9- $21
Federal Mogul sealed power pistons- fastengineparts.com PN 1079p- $160
Piston rings- fastengineparts.com PN 568- $39
Comp Camps pushrods- Summit PN cca-7812-16- $30
Stock rocker arms
Oil pump
Fel Pro gaskets- Summit PN fel-ks2002- $89
Bolt kit- Where to get?
Valves- Where to find? Anyone make recessed ones?
Edelbrock valve springs- Summit PN edl-5832- $63
Valve guides- Axed
Valve seals- These come with gasket kit
Valve covers- Where to find?
Cloyes timing set- Summit PN clo-9-3118- $100
Proform HEI distributor- Summit PN pro-67185- $210
Thanks
Gremlin4ever
Bolt kits:
ARP from Summit, head, main, rod are the most important kits. They also have assesory bolt kits (intake, timing cover, oil pan, valve cover, header, water pump and thermostat housing) available too, you'll just have to ask them to look up the part number as it isn't listed in their catolog.
ozzman104
there's a lot of stainless bolt kits on ebay. actually you can find quite a few amc v8 parts there
BREK
valve covers you can get right here in the e-store
If I might make a suggestion. A stock 360 or 401 will fit in place of the 304 and with s simple freshen up overhaul will outperform the 304 even a moderately warmed 304. just something to consider.
