jeep_man_401 wrotenope...it got to about 220...but then settled in pretty good...about 10.5 to 1 with a 2 row rad. (for now). What did the other guys do to "under pressure" the Indy cover. (They make 2 pumps....one a high vol that they requmind for stock engines and one regular one they use on they block) I susspect that the high vol. is just to damn big.
A geared pump cannot build pressure without restriction. Were your clearances correct? I'm running .0035 clearance on the rods.. A loose engine never seizes. If the small spring was too much what else can you use? Too much oil pressure will spin bearings, if you have to build the bottom end a second time, dowel pin the bearings. And add some pressure reliefs cutouts at the connecting rods ( use a surface grinder with a 1/2 inch wide wheel, .010 deep) although I also have a pin oiling hole. I heard thru the grapevine some new engines don't even use the tang on the bearing or have a cutout at the rod or main anymore. I'm very interested on your findings.
Jeff
