OLD SCHOOL CJ
WHAT STALL RANGE IS BEST FOR A CJ7 WITH A 304 37 TIRES 427 GEARS THE 304 HAS A TORQUE CAM AND A 750 CFM CARB WITH A TORQUER MANIFOLD MSD IGNITION HEADERS DUAL EXAUST AND NO SMOG AND NO SMOG STUFF. I USE THIS JEEP FOR OFF ROAD ONLY SOME ROCKS,SAND MUD AND TRAIL THE 304 ALSO HAS 360 HEADS THANKS FOR ANY HELP
1500 or stock
OLD SCHOOL CJ
HOW CAN I TELL IF THE TORQUE CONVERTER IS GOING BAD?
Briteblock
Its hard to tell...it either makes noise or doesnt transmit power. Rebuilt units are only drained and plug welded.
KJMac
Which cam do you have? If it is bigger than stock I thin you would benefit from a 1800!
