JeepinCT
Installed a new oil pan gasket- cork and used ATV sealer- just a thin film. Torqued to 14lbs and the sucker slid out.. loosted and tried again with the same results.
Do I need to 1) ditch the sealer, use another type, let it dry first, find a rubber gasket....make my own rubber gasket
NEED Help please as my Jeep is not happy. :(:
You probly had oil on the mating surface. You can use hi-tack or many other tacky gasket retaining sprays...sounds like a re-install
JeepinCT
Had the surface really clean-? thought the ATV Silicone made it slide. Yes, it's a re-do- would prefer to find a rubber gasket or one with metal bolt holes.......
I never coat cork gaskets with any type of RTV. Like mentioned above, clean both surfaces of all oil (I use brake cleaner). Use permatex hi-tack or trim adhesive on ONE SIDE ONLY. I usually glue the gasket to the block, since it's held on the ends by the rubber seals. I do put a dab of RTV where the cork gasket meets the rubber end pieces. Also, DO NOT over tighten. Watch closely near the bolt, when the gasket bulges out slightly, that's tight enough.
Also, check the pan surface around the bolt holes. Make sure they're flat. If the pan has been overtightened at some time in it's life, chances are the surface is sucked up around the bolt holes. If it isn't flat, it will never seal. You need to tap the sealing surface flat before installing the pan.
JeepinCT
Great feedback- thank you! :wink:
youdidwhat
when useing a sealer with a gasket I like to tighten to half torque and let it set for 15 min before I finish torqueing the bolts.
just my .02
JeepinCT
This did not slide- used a very minimal amount of ATV
