Don't rely on Desktop Dyno for numbers as it's pretty far off base. Numbers we got from it on a recent Mopar 408 stroker build were way low (405HP/470TQ), but once we got it built and put it on a real dyno we were happily surprized with 453HP @ 500rpm and 507ft-lbs @ 4000 (with over 450ft-lbs from 2000-6500rpm). On the other hand, I know a few people who have had just the opposite exerience where DD gave them higher numbers than what were achieved on a real dyno.
My recommendation is to use the DD software only to compare cams. First your basic engine specs entered (bore, stroke, heads, intake, carb, etc.), then plug in different cams making no other changes. Note the increase/drop in HP and TQ numbers across the board, and also where those numbers are peaking (rpm). While one cam may give you an additional peak 15-20ft-lbs or HP, you'll also usually notice a significant drop in low end torque. This will help you pick the cam that will potentially make the best power in the RPM range you're looking for.
Of course, you also have to remember that the software assumes everything else is perfect in regard to engine tuning.
Here's a setup I just threw together for shits & giggles:
Bore: 4.11"
Stroke: 3.45"
Heads: Edelbrock Performer RPM (the flow numbers I got on these vary slightly from those posted above, but every flowbench will vary slightly)
Valves: 2.02/1.60
CR: 10.5:1
Carb: 670cfm @ 1.5 inHg
Intake: Dual Plane Std-Flow
Exhaust: Large tube headers w/mufflers
Cam: Summit 8600
Cam Installed Timing: 0
Here's the exact same setup with the Summit 8601 cam. One would think it would make more power due to the increased duration and lift, but as you can see that simply isn't the case. Both peak HP and TQ are down compared to the 8600 clear across the board.
