What is the difference between the Select Track and Quadra trac?
Situation:
Younger bro has a 1994, 5.2L, fully loaded ZJ (the white one he had at the FSJ Invasion), the 'service 4WD' light comes on, goes off, comes on, goes off randomly. He's replaced the sensors - no cure.
The 'Service trans' light is doing the same thing, and he said it feels like it's slipping sometimes - or at least not shifting right at times, then at others runs fine.
The shop plugged him up and the error code says the E-Prom is bad ($200 replacement, $400 for the perfomance setup from HyTech).
What are his options - I'm not even sure what tranny/T-case he's got, he's looking at changing all that crap to get away from the comp-u-tater contol. His is newer than the Heeps I work on 111!!! and the Jeep Bible doesn't go there??
Comments? Suggestions??
Thanks
Pat
