Brett Polwell I have put a Dana 60 with drum brakes and a Dana 44 with discs under my 91 Wrangler. I have put new brake lines on, bled the brakes but the pedal still goes to the floor. I have read that you can adjust the rod but I get the feeling I really need a bigger Master Cylinder. I am wondering if an 86 E350 van master cylinder will work. I have also read that a 69 corvette mc will work. Which is the better choice and what is involved with making everything work. I also need to make sure the Dana 60 is a 35 spline so I can order a spool. It is out of a 75 J20 Quadratrac. Thanks!
Lifted79CJ7 http://www.bulltear.com/forums/viewtopic.php?t=851 Check out that thread. If you don't see it in the thread, scroll to the bottom for the link to look up your BOM.... Jack
