Hey,
OKay some background is in order I suppose. This was my dads hunting rig back in Florida. The Previous owner before him was the Original owner of the Jeep so it hasn't passed many hands.
Since my dad has had it (about 4 or so years) it has had piss poor brakes. When he finally shipped it down to me I have done my best to correct the problems as they come and have been fairly successful. The tub itself is in pretty damn good condition for its age, just needs a new floor, side walls are immaculate as is the frame. It came from the factory with 4 wheel power drum brakes.
Now when I finally busted a brake line I decided to replace the entire rear (from the prop valve) half of the brake lines. I also installed a new Master Cylinder and installed new Wheel Cylinders and adjuster kits in the rear drums. When I pulled them off and did a good inspection, I realized the entire brake system was stock, from the factory stock. The wheel cylinders were leaking, the hardware in the drums was backwards (which explains the zero wear on the shoes which were also coated in Brake fluid).
So over 2 weeks in-between work and school I replaced the adjuster parts, shoes, wheel cylinders, brake lines, and master cylinder hoping it would at least boost the brake power. I am going to replace the Booster as well as its pretty damn rusted and gone.
Now,
I have NO leaks anywhere in the brake system, I have been watching. So I'm guessing from the information you posted there is still air somewhere in the system.
When I slam on the brakes at low speed the jeep does nose dive a little. Before all this work the rear drums were adjusted all the way in (on purpose) so they were not in touch with the drum as the wheel cylinders were fscked anyway and I didn't have the time to fix it). So the front brakes were doing all the stopping.
Most of the time when I slam on the brakes, nothing happens until I start pumping. When it does stop I hear a slight groan from the rear brakes and slight rubbing from the front.
It doesn't get very hard when I pump with no engine power and when the engine is running its very very very very to the floor with pinky finger soft.
P.S. I'll fix the picture in the mod forum 🙂
-Dave
