plasticboob
Hi, I bought the Ni timing cover and oil filter adapter plate. My old cover was for a '74, where you install the seal from the back side, and the fuel pump mounted with the inlet and outlet ports pointed down. Can I install my old fuel pump on this new cover pointed up? I haven't had a chance to take a look at it to see if it would work. Also, I'm assuming the new cover has the type of seal that can be installed from the front? Thanks!
