AMC 360:
- Machined .060 over
- Crank was polished, valves refaced and new valve guides installed
- All bearings/gaskets and freeze plugs replaced
- Oil bypass upgrade
- Distributor gear oil sprayer
- 343 High compression pistons, 4 barrel
- New Edelbrock Performer-Plus Cam, Performer Intake Manifold, Sure seat valve springs, and valve spring retainers.
- Anti cam walk kit
- New Distributor gear & Cam gear
- New exhaust manifolds
- New FlowKooler water pump
- New M.O.R.E Bombproof motor mounts.
This engine was for an CJ8 chassis that I bought to restore, but I don't have the time. This engine has never been started. It was professionally rebuilt and put in the chassis and has been sitting for the past year. I do crank it over a time or two every month. Complete from oil pan to intake manifold. TBI not included. There is over $2800 in parts and machining alone. Have all receipts.
asking $2000
Machine shop stated it would easily be over 300HP as it sits. 😃
I prefer pickup, will crate and drop off at a foward air for $20
My zip is 63301
-Austin
