My 360 has the valley line but nothing else. For a low RPM engine, I would probably just go with drilling the smaller holes in the cam bearings (that mod wasn't in print when I built mine). I've seen lots of factory cam bearings break down, causing low oil pressure, so it's cheap insurance to have them replaced anyway.
Mine pushes around 55 PSI over 1500 RPM and idles at about 20 PSI (both hot). I have MC's remote filter and replacement pump cover, but I haven't had time to install it yet.
I had good luck with a Holley 600 on mine. I did upgrade it with off-raod float bowls, a "whistle" and slosh tubes. The only time I had a problem with it was a quick drop of the front end (like dropping off a ledge), or extreme nose down attitudes. I think the truck avenger series of carbs have all those mods out of the box. Fuel injection is worth it. You might check with www.howell-efi.com , for just a little more than the cost of a new avenger, you could buy the harness, tbi adapter, and chip from them. The rest is 92-95 GM parts (TBI, MAP, temp sensors, and ECM) that you can get at a junkyard. Mine starts better, idles smoother, gained about 1 MPG, and even runs upside down (don't ask how I know #-o ).
