grignac48
I am trying to locate a 401 crank in rebuildable or useable shape. The machine shop said that my current crank has too much front to back endplay on the mains. Or is it possible to repair this?
thanks :shock:
grignac48
Alright, :smile: This is what I know. The machine shop says that the bearing surface on the mains are too wide by 2 thousandths. However, looking at the bearings only one of them has a lip for the main thrust surfaces.
Are these guys off base here? Any comments. I am getting the crank back and I am going to reinstall it with the old bearings and check the end play and see if it is really that bad. These guys know chevy and fords but not AMC's They have been wrong once on another issue. :razz: :idea:
2 thou!!! Take it somewhere else
grignac48
This is the deal. The the main thrust bearing is worn on the rear side and no longer flat about 5-7 thou. It has a ridge. IF I grind the mains 10 thou and get oversize bearings does the thrust surface bearing also come oversized as well? Or is it only the crank portion that is oversized? ](*,)
grignac48
Update. You were right jeeps4ever. I got the Crank home after they said it was a total loss. I mic d out all the surfaces. There is a small ridge of less than a thousanth. You can almost feel where the oil chanel was. Other than that the crank is fine. I don't know what those guys were measuring 111!!!
I polished up the bearing surfaces and now for a cleaning and off I go. Got get me one of those bulltear timing covers yet. :lo1l:
When it warms up I will be ready for 401 assembly. :sa: :t: :!:
