If I remember correctly the 82 has fusable links up by the solenoid. If the one to the alternator is blown you will have no powere to the starter.
Have someone in the drivers seat for you and check the voltage to the starter side if the solenoid in start mode. Then work your way back to find the problem.
See http://oljeep.com/ for wiring diagrams.
If you do good with manuals - I could scan and send you the trouble shooting guide from the TSM.
S
