Just a quickee...
Bulltear is about (?) to release a dry-sump pan & already has a dry-sump oil pump cover available. Way better than swinging p/u.
You will need to make SURE that the cam bearings go in correctly, find an experienced AMC/Jeep builder. You will need to be SURE that the timing chain cam gear was machined properly and installs correctly. Same for the distributor drive gear & driven gear, Bulltear sells a matched set - get a set. I think there is a thread devoted to that exact topic, so find it and do read it. ("About distributor gear wear").
There is even a main topic called "AMC oiling" http://www.bulltear.com/forums/viewforum.php?f=25
There are some threads in the "How to" topic on oiling.
I would not go as low as 9.51, myself. If you do want to be conservative, 101 or 10.51 will be OK so long as you keep the piston .045" to .040" (minimum, .075" for aluminum rods) from the head. If you get too much dish it will ping even on 104 octane. Your machine shop will have to "CC" the heads to see what they are starting with, there is a formula for determining how much milling increases the compression by what factor. I believe it was +.22 CR per .010" milled, on my 53cc heads.
In cams, I think a lot of manufacturers just use smallblock chevy type grinds. There are a few that have grinds SPECIFIC to the AMC, a little research at this site will reveal the answer, I believe.
I wouldn't buy a kit. FelPro makes good head gaskets & rubber valve cover gaskets. Then you will need a pan, timing chain cover, intake, & water pump gasket. Plus seals & freeze plugs.
I would also advise that you have your machine shop set the heads up for "PC" seals, the beefier 7/16" screw-in rocker studs, a 1.95" tall spring, & while they are machining for that, have them machine for spring seat cups to fit your 1.55"1.65" diameter springs. I have seen a few valve springs that get to spinning & dig in to the shims & destroy the shims (shrapnel) & break off at the thin spring tip, the cups should solve that. Now would be the time to do that so you aren't locked in with short & small dia springs forever. You may want to up the power later w/o having to pull heads.
Are you getting it bored? More decisions there, lock in to 5500 or enable higher RPM & higher horsepower. The thing is, if you DO go for more HP, you will likely end up with more torque as well. But I've been all through that previously.
None of the mods I have just talked about would be "race" & reliability would really be improved, until you rev it past what you have built it to run. Nice to have those off-brand beasts behind you, eh?
quickee????????? ooops
