Well, I'm about confused on this one.
The engine:
4.2L, bored .030 over, cross drilled, ground and polished crank, stock cam, balanced rotating assy, minor smoothing on the ports (nothing radical), valve spring pressure was matched when the head was reworked by the race shop, stock intake, exhaust, Weber 38 DGES carb. New fuel pump, water pump, Alt, rebuilt P/S. Belts are fine (new) and tight, oil pres 50# running about 20# at idle. Oh yeah, less than 1000 miles on the rebuild.
The problem:
I can get it to start and run, got the timing set fine (total of 24* at 1600 RPM), runs really well - then dies at speed. Starts right back up when cool, takes a couple tries when at temp, but starts and runs.
Daughter child (her YJ) has had it die several times to/from school (4 miles) and didn't even make it out of the driveway this AM (25 yards) 111!!!
What I've done (three times):
Double checked timing
Checked for Vac leaks with either
Readjusted the lean idle circuit on the Webber
Tried to rationalize the vac lines since I don't have all the smog crap the 'plumbing' ... um ... is .. ah ... different than the TSM.
Checked the timing again
Test drove it again tonight and it 'stumbled' a couple times slowing down for a stop lights/signs, but didn't die when stopped. Got back to the house and let it idle and it would randomly 'stumble' every 20-30 seconds. Exhaust smells a little rich but not terrible.
I put the timing light on it with the vac line still on the dizzy and the timing was jumping all over. That should tell me there is a vacuum leak somewhere but I'm not so sure any more
Could I be pulling to much vacuum somewhere?
Anybody got any clues here????
Thanks
Pat
