Thanks for the recomendation on the book.....I ordered it today.
HOUSTON, we have a problem......
I took the pistons out today and the main caps. Rod #1 had NO bearing material at all in it and was flopping around so badly that the piston was bottoming out on the crankshaft counterweight. The bearing surface on the crank is visably smaller on the #1 side than the #2 side. Does this mean all will need to be ground or just the first? I was hoping to get away with polishing, but it will require turning the crank to some degree.
https://forum.bulltear.com/assets/migrated-images/MAINCAPS1_63e3350d.jpg
https://forum.bulltear.com/assets/migrated-images/MAINCAPS2_2664a0a4.jpg
https://forum.bulltear.com/assets/migrated-images/MAINCAPS3_9d8c54ee.jpg
https://forum.bulltear.com/assets/migrated-images/MAINCAPS4_29a9297c.jpg
https://forum.bulltear.com/assets/migrated-images/MAINS12_951bd4a3.jpg
https://forum.bulltear.com/assets/migrated-images/MAINS34_518c9bf0.jpg
https://forum.bulltear.com/assets/migrated-images/MAIN5_2667cf07.jpg
https://forum.bulltear.com/assets/migrated-images/RODS12_975f2144.jpg
https://forum.bulltear.com/assets/migrated-images/RODS34_599fa1f8.jpg
https://forum.bulltear.com/assets/migrated-images/RODS56_b7bf19b7.jpg
https://forum.bulltear.com/assets/migrated-images/RODS78_8097d9df.jpg
Judging by the photos, can anyone tell anything about the crank that may be helpful? I also took off the thing that the oil filter screws on....like 7 small bolts...what is this called? There are 2 gears underneath it which did not turn when I turned the crank. I have removed the dizzy. Is this normal? Does the dizzy somehow drive these two gears or have I found the reason the first 2 rod bearings were shot?
Do you have to remove the H-Balancer to get the crank out? Do you need a puller for this? Do you need to make sure the balancer is "clocked" in the same position when it is put back on?
After I get the balancer off, can I just unbolt the stuff on the front of the motor ( timing cover, etc ) and pop it off or is there more to it? I know I will need to do some thing with the timing chain & cam, but what? Is there a thread that details this part of the disassembly?
I know this is alot of questions and I do appologize for my ignorance , but I am getting pretty excited so far, and a bit nervous , at the idea of building this thing myself.
Thank you again to everyone, please keep the info coming.
Dave
:lo1l:
