jeepsr4ever wrote73 you might be thinking about the toronado overhead cam 6
232/258 oiling system from 71 tsm. Rocker shaft, not cam shaft. Oil feeds through #3 cambearing up through the tower that supports the rocker shaft. If the rocker shaft is installed 180 out, then the feed hole would be blocked off.
