tarra wroteI am new to these 6 cylinders and would like to know what the differences are and what is interchangeable.
Also can a normal AMC T-10 and bellhousing go behind them?
Any help or direction would be apprecitated.
Thanks
Adam
Hi Adam, and welcome to the world of straight 6's :t: Just remember we get no respect, and about as many custom parts :roll:
Most everything in the 232 and 258 are the same and share the bell housing pattern. Bore is the same at 3.75, but the stroke is different (crank) 3.50 on the 232 and 3.90 on the 4.2L. Compression is a point lower too because of that ... 8.5 vs 9.5 in the 4.2. I've heard the deck hight is a bit different, but can't confirm that anywhere. But swap them cranks, keep the rods and you should be golden :wink:
And if it's any consolation, we have a local ball player (for the Tides) that is having my local hot-rod shop put a blower on a 232 :shock: So some neat parts can be had $$$
Not familiar with the T-10 though? :-|
pat
