psycholist69
I am selling my 74 Jeep cj5, it is located in Kansas City, and is in pieces in my garage. The original frame is cracked , but I have a spare for it which needs to be welded in the front,by crossmember and the original frame has the following still attached :
- 304 w/ Isky cam and lifters, edelbrock 600 carb and intake, MSD 6AL ignition & dist, hedman in frame headers, heads rebuilt with edelbrock springs, rebuilt 2 yrs ago, with around 5k on it.
- 3 row radiator new with rebuild
- dropped pitman arm, new tie rods
- (FR) dana 35 w/ 4.56 and lockright drums, have spare 35 with discs for conv
- t14 & dana 20 ( tranny is locked, think t-case is still good)
- (R) dana 44 w/ 4.56 and lockright, drums
EVERYTHING ELSE IS OFF FRAME
- painless wiring harness unhooked (new with motor rebuild)
- tub is off and needs either rust repair to supports or replaced
- have grill, hood, and tailgate
- full 6 pt rollcage
- dash with all gauges and new sunpro oil temp, temp, and, amp guages
- T176 tranny newly rebuilt
- dana 300 t-case newly rebuilt
- set of 5 32x11.5x15 mud kings like new on alum MT classics
- winshield w/ new glass
- Warn 8000lb winch (no cable)
- Optima battery (new)
- larger master cylinder for discs
- seats with 4 pt harness (fronts only)
- besttop in good condition w/ soft doors
- 3 gallons of off brand line-x with spray gun(yellow and blk) this is enough for undercoating, inside tub and engine compartment
- tilt column
- new in box upper and lower ball joints
- new in box brake pads for drums (2 sets)
- 2 / 5 gal cans
I would like to sell everything together, but will seperate what I can. I am asking 2000 for the whole shootin match. You pick it up. Would also accept trade for running 4 or 6 cylinder pick up. This was my daily driver and $ ran out, so I am truying to get new wheels.
I have no pics but will try and get some. I can be reached at 816 255 9206
