...in addition, if you are getting a crank out of a run of the mill 401 Jeep, it has probably never seen 5500 RPM and has lived its life with a very low compression ratio, never coming close to stressing the crank & rods.
Here's the specs I got for offset ginding a 401 crank:
Magnaflux, offset grind 401 crank to SBC SJ 2.0" (3.93" stroke), 1/8" filet radius, nitrate, nitride, knife edge, lighten, internal balance $1,050 at Speed-O-Motive
As far as using a 401 crank in a 360 block, all of the AMC blocks (68 & up) have the same main journal size and bore spacing, so I don't know why a 401 crank would not fit. But I think the 401 block has thicker webbing, making it stronger. I never considered using a 360 block since 401s can be had at a fair price.
