Iguess this is the part that confused me ... crossed close to the pumpkin ...
Dusty wrote the only way is a double crossed chain onto the axle housing close to the pumpkin so as not to leverage the tubes and bend them and to prevent the tube from moving horizontally in the crossed chains ...
Seems that would be like standing in the middle of a long board between 2 saw horses at each end (not that I have EVER have done that :oops: ) But you get the picture ... the board bends in the middle much like (I think) an axle under 5-8K pounds of tension would. I can see the crossed chains to control lateral movement. But wouldn't coming off the spring perch area be better? Or is that what you ment with the cross over close to the diff?
Dusty wrote I know i have issues 🙁:
So ... Dusty ... just lay back, close your eyes and tell Dr. Pat what issues you think you have ...
Ah ... I see ... Zo, you tink your mudder tied you down too tightly in your crib? Huummmmm, Ya. You didn't haf zee fareedom to move. Vely intelesting 111!!!
Pat
