HotJimmy
On my next motor build, what cam do you recamend to get more rpm's. In a pipe dream, I would like to get close to 7,000 before my valves float. My curent 401's float at 5500-6k. What other tricks do you advise? I'll probably go expensive and make it a full roller motor as well.
Thanks for any imput. :t:
fuzz401
polish and shot blast your rods balance the crank and rods and then a good solid lift cam
BREK
On top of what fuzz said I also would use either a Milodon or Canton
single or dual external pickup oil pan :lo1l:
radamx
And lots of head work to get a 401 to make power up there other wise you are just wasteing your time.
HotJimmy
what head work would you do to the edelbrock heads? probably my next purchase
Match the ports and polish the bowls. The biggest error in the Edelbrock heads is that they made a smaller than the port dog-leg....probly so cusotmers can customize it...
